External Flash Problem
mxl
Sorry for this stupid question, but I can't understand - how i can use hotshoe external device (Multiblitz Infrared transmitter) - if i can't switch flash mode to "External Flash"? I dont see this position in my menu - just "Flash Off", "Auto", "Red Eye" "Flash On" and "Syncro"!
0_1ef95_c2f03a06_L
thanks a lot for your help.
I don't have any external flash to test, but I guess this menu option is available only if you have attached an external flash (most probably Sigma TTL compatible)? I wouldn't be surprised if it does not work with "dumb" (one pin) flashes and flash accessories.
I'm sure you can use one pin flashes with GRDII. A lot of people uses them (mainly Metz 20 C2). But I don't have any clue if the external Flash menu item is there or not?
